Need to know which domains Mailspring contacts for update checks (blocked by my network filter)
Hi ,
I’m trying to let Mailspring check for updates, but my network’s web filter is blocking the connection. I’d like to request my network admin to unblock the necessary domains.
I tried using CurrPorts and ProcMon to capture which host(s) Mailspring connects to during the update check, but I couldn’t identify them with certainty.
Could anyone please let me know the exact domain(s) or endpoint(s) that Mailspring uses for update checks?
Thanks in advance!
Can anyone help me with this? I would assume its pretty simple.. @bengotow
Hey Technobulb! We actually put the update checker on it’s own subdomain just for this purpose - if you block updates.getmailspring.com you’ll be set.
