It works correctly for me, I don’t remember if I had to touch the settings (bit for sure I did not use any specific command line arguments). I’m using the rpm version, not a flatpack
Similarly, it worked as expected for me without having to tweak anything: my KDE panel has a Global Menu and Mailspring puts the application menu into it.
Kubuntu 20.10, Mailspring 1.9.1 snap version installed from Software Centre
