I absolutely love Mailspring, but I can’t seem to figure out how to use the Microsoft Office feature of File>Share>Send Document with Mailspring as my default email client.
If I change my email client to Mail or Outlook inside the Mail app, the feature on MS Word works fine. Is there a setting I need to change inside Mailspring for this to work?
There’s no setting in Mailspring that will make this work, unfortunately. “Default mail client” on macOS only decides who handles mailto: links, which can’t carry an attachment. Word’s Share > Send Document feature doesn’t go through that - as you found, it talks to Apple Mail and Outlook specifically, and there’s no generic hook a third-party client can register for. This is a gap on our side rather than something you’ve misconfigured.
The workaround I use: save the document, then drag it from Finder onto the Mailspring icon in the Dock. Mailspring accepts any file that way and opens a new draft with it attached (right-click > Open With > Mailspring in Finder does the same). You can also drag files directly into a draft you already have open.
