Running npm run test results in Electron launching with a blank white window. The renderer fails during startup and does not complete initialization. However, npm start does succeed in starting the application normally.
The issue occurs after running npm install. The failure reproduces consistently and is not limited to a single platform.
- Clone the repository
- Run
npm install - Run
npm run test - Electron launches with a white screen
npm run test should start the test runner successfully and render the application window.
OS and Version:
Windows 10 Pro x64
Installation Method:
Source build from GitHub repository
Mailspring Version:
Source build
Node and npm:
- Node 20.x
- npm 10.x
Error output during test startup:
Error: Package subpath './lib/utils' is not defined by "exports" in W:\Github\Mailspring\app\node_modules\cheerio\package.json
Full stack trace:
index.js:26 Error: Package subpath './lib/utils' is not defined by "exports" in W:\Github\Mailspring\app\node_modules\cheerio\package.json
at exportsNotFound (node:internal/modules/esm/resolve:317:10)
at packageExportsResolve (node:internal/modules/esm/resolve:664:9)
at resolveExports (node:internal/modules/cjs/loader:657:36)
at Module._findPath (node:internal/modules/cjs/loader:724:31)
at Module._resolveFilename (node:internal/modules/cjs/loader:1376:27)
at Module.a._resolveFilename (node:electron/js2c/renderer_init:2:4859)
at defaultResolveImpl (node:internal/modules/cjs/loader:1032:19)
at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1037:22)
at Module._load (node:internal/modules/cjs/loader:1199:37)
at Module.c._load (node:electron/js2c/node_init:2:17993)
at Module.s._load (node:electron/js2c/renderer_init:2:34480)
at TracingChannel.traceSync (node:diagnostics_channel:328:14)
at wrapModuleLoad (node:internal/modules/cjs/loader:244:24)
at Module.require (node:internal/modules/cjs/loader:1470:12)
at require (node:internal/modules/helpers:147:16)
at Object.<anonymous> (../src/Utils.js:10:1)
at Object.<anonymous> (W:\Github\Mailspring\app\node_modules\enzyme\build\Utils.js:497:3)
at Module._compile (node:internal/modules/cjs/loader:1714:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1848:10)
at Module.load (node:internal/modules/cjs/loader:1448:32)
at Module._load (node:internal/modules/cjs/loader:1270:12)
at Object.<anonymous> (../src/ReactWrapper.js:4:1)
at Object.<anonymous> (W:\Github\Mailspring\app\node_modules\enzyme\build\ReactWrapper.js:2006:3)
at Object.<anonymous> (../src/index.js:1:1)
at Object.<anonymous> (W:\Github\Mailspring\app\node_modules\enzyme\build\index.js:42:3)
at Object.<anonymous> (file:///W:/Github/Mailspring/app/spec/spec-runner/spec-runner.ts:3:1)
at Object.<anonymous> (W:\Github\Mailspring\app\spec\spec-runner\spec-runner.ts:183:3)
at Object.value [as .ts] (W:\Github\Mailspring\app\src\compile-cache.js:145:21)
at Object.<anonymous> (file:///W:/Github/Mailspring/app/spec/spec-runner/spec-bootstrap.ts:15:1)
at Object.<anonymous> (W:\Github\Mailspring\app\spec\spec-runner\spec-bootstrap.ts:14:3)
at Object.value [as .ts] (W:\Github/Mailspring/app/src/compile-cache.js:145:21)
at setupWindow (file:///W:/Github/Mailspring/app/static/index.js:48:3)
at window.onload (file:///W:/Github/Mailspring/app/static/index.js:69:5)
Observed dependency tree after npm install:
mailspring@1.17.2 app
├── cheerio@1.2.0
├─┬ enzyme@3.11.0
│ └── cheerio@1.2.0 deduped
└─┬ juice@11.0.3
└── cheerio@1.0.0
Observed diff in app/package-lock.json after npm install:
- cheerio@1.1.2
+ cheerio@1.2.0
- electron@39.2.7
+ electron@40.0.0
- undici@7.18.2
+ undici@7.19.1
- @types/node@22.x
+ @types/node@24.x
The behavior reproduces consistently following these changes.
