Using the wizard to add a Office 365 account, fails.
The checkout page https://id.getmailspring.com/oauth/finished does tell “You’re all set”.
Inbox authentication seems to work:
'2 OK AUTHENTICATE completed.\r\n' +
'3 CAPABILITY\r\n' +
'* CAPABILITY IMAP4 IMAP4rev1 AUTH=PLAIN AUTH=XOAUTH2 SASL-IR UIDPLUS MOVE ID UNSELECT CLIENTACCESSRULES CLIENTNETWORKPRESENCELOCATION BACKENDAUTHENTICATE CHILDREN IDLE NAMESPACE LITERAL+\r\n' +
'3 OK CAPABILITY completed.\r\n' +
'4 NAMESPACE\r\n' +
'* NAMESPACE (("" "/")) NIL NIL\r\n' +
'4 OK NAMESPACE completed.\r\n' +
'login ok\r\n' +
'5 LIST "" "*"\r\n' +
'* LIST (\\HasNoChildren) "/" Archiv\r\n' +
(listing of folders continues)
Problems start with outgoing authentication:
'----------SMTP----------\n' +
'connect smtp.office365.com 587\r\n' +
'220 <subdomain>.outlook.office365.com Microsoft ESMTP MAIL Service ready at Tue, 16 Nov 2021 10:15:24 +0000\r\n' +
'init\r\n' +
'EHLO <local_hostname>\r\n' +
'250-<subdomain>.outlook.office365.com Hello [176.96.155.207]\r\n' +
'250-SIZE 157286400\r\n' +
'250-PIPELINING\r\n' +
'250-DSN\r\n' +
'250-ENHANCEDSTATUSCODES\r\n' +
'250-STARTTLS\r\n' +
'250-8BITMIME\r\n' +
'250-BINARYMIME\r\n' +
'250-CHUNKING\r\n' +
'250 SMTPUTF8\r\n' +
'start TLS\r\n' +
'STARTTLS\r\n' +
'220 2.0.0 SMTP server ready\r\n' +
'done\r\n' +
'OpenSSL version: OpenSSL 1.1.0f 25 May 2017\r\n' +
'init after starttls\r\n' +
'250-DSN\r\n' +
'250-AUTH LOGIN XOAUTH2\r\n' +
'AUTH XOAUTH2 <secret stripped>' +
'451 4.7.0 Temporary server error. Please try again later. PRX5 [<subdomain>.PROD.OUTLOOK.COM]\r\n' +
'\n' +
'\n' +
'SASL_PATH: /usr/share/mailspring/resources/app.asar.unpacked\n' +
'\n' +
'SMTP Last Response Code: 451\n' +
'SMTP Last Response: 4.7.0 Temporary server error. Please try again later. PRX5 [ZR0P278CA0186.CHEP278.PROD.OUTLOOK.COM]\n' +
'\n' +
'\n' +
'mailsmtp Last Error Code: 1\n' +
'mailsmtp Last Error Explanation: MAILSMTP_ERROR_UNEXPECTED_CODE\n' +
'mailsmtp Last Error Location: 10\n' +
'mailsmtp Last Auth Type: 256'
} { pluginIds: [] }
(node:227164) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
Raven: 429 - undefined
Adding the same account on the same machine using i.e. evolution-ews works.
This is why assume no DNS or other misconfiguration.
- use the wizard to add an “Office 365” account
- authenticate in your web browser
No authentication error
- OS and Version: debian 11.1
- Installation Method: .deb
- Mailspring Version: 1.9.2
