Sorry but all of these solution do NOT work on arch CachyOS and I am just about to give up.My config file looks like this:
mailspringCONFIG.log (3.0 KB)
Hiya,
I have given up and went with Betterbird client instead: https://www.betterbird.eu
No issues of passwords in the cloud anymore …
Same issue, clean install Ubuntu 25.04, happens in both snap and deb files, and using mailspring --password-store="gnome-libsecret"does not work. Sigh.
I am on version 1.15 on Zorin OS. Still I am getting the same error (that has been shared as screenshots multiple times in previous posts).
4 years old thread, is this issue still not resolved?
On openSUSE SLow Roll / KDE 6
MailSpring rpm or flat pack, both give me the error about “could not store your password securely”
“Workaround” please ?
I subscribed to the monthly payment to support the project
forget it. Went back to Thunderbird for now.
MailSpring way of doing thing is very promising.
Same issue. Nobara 42 with Flatpak. Tried everything afa command modification and flatpak override to both kwallet5 and kwallet6. Nothing will work. ABORT!
For those using NixOS with gnome-keyring, looking to persist the password store parameter, I simply overriden the postFixup attribute when installing the package. This attribute was already overriding the Exec param in order to link to the Nix’s store so it was just a matter of providing the option at the end. Works flawlessly!
This is how I got it to work for people using the flatpak version in KDE 6. In Flatseal, I added these:
org.kde.kwalletd5
org.kde.kwalletd6
To the session bus “talk” section. And that’s it, no params needed (at least for me in Bazzite 42)
Dude - Brilliant - this was the only way I could get Mailspring to work in Nobara 43. Thanks very much for posting.
Perfect! Works on Fedora 43 with KDE Plasma
Amazing, works on CachyOS
Im new to Ububtu LTSE version… is there a simple way to make this work?
The solution of editing the .desktop file works, but breaks seemingly every time Mailspring updates. Is there a way to make this solution more permanent?
The solution of adding the line below worked but would only apply when launching using the shortcut.
mailspring --password-store=“gnome-libsecret”
I had to paste into the EXEC line of the desktop file in my autostart folder if I wanted the changes to persist on system restart/bootup. Is this the proper way of making this work or is there another solution out there?
