Protonmail is completely broken after the update. It seems there is a problem with syncing.
Mailspring Version: 1.26.2-4de23b01
Platform: win32
Account State: sync_error
Account Provider: imap
IMAP Server: 127.0.0.1
SMTP Server: 127.0.0.1***
24408 [2026-10-30 21:37:54.342] [main] [info] Identity created at 1766784548 - using ID Schema 1
24408 [2026-10-30 21:37:54.342] [main] [info] ------------- Starting Sync ( ) ---------------
24408 [2026-10-30 21:37:54.346] [metadata] [info] Metadata delta stream starting…
24408 [2026-10-30 21:37:56.349] [background] [info] Marking all folders as `busy`
24408 [2026-10-30 21:37:56.350] [background] [info] Syncing folder list…
24408 [2026-10-30 21:37:56.492] [background] [critical]
*** {“debuginfo”:“syncFoldersAndLabels - fetchAllFolders”,“key”:“ErrorCertificate”,“offline”:false,“retryable”:false,“what”:“Unknown exception”}
***13716 [2026-10-30 21:37:57.393] [main] [info] Identity created at 1766784548 - using ID Schema 1
13716 [2026-10-30 21:37:57.393] [main] [info] ------------- Starting Sync ( ) ---------------
13716 [2026-10-30 21:37:57.396] [metadata] [info] Metadata delta stream starting…
13716 [2026-10-30 21:37:59.402] [background] [info] Marking all folders as `busy`
13716 [2026-10-30 21:37:59.402] [background] [info] Syncing folder list…
13716 [2026-10-30 21:37:59.535] [background] [critical]
***3796 [2026-10-30 21:38:00.880] [main] [info] Identity created at 1766784548 - using ID Schema 1
3796 [2026-10-30 21:38:00.880] [main] [info] ------------- Starting Sync ( ) ---------------
3796 [2026-10-30 21:38:00.883] [metadata] [info] Metadata delta stream starting…
3796 [2026-10-30 21:38:02.885] [background] [info] Marking all folders as `busy`
3796 [2026-10-30 21:38:02.885] [background] [info] Syncing folder list…
3796 [2026-10-30 21:38:03.032] [background] [critical]
***38052 [2026-10-30 21:38:03.981] [main] [info] Identity created at 1766784548 - using ID Schema 1
38052 [2026-10-30 21:38:03.981] [main] [info] ------------- Starting Sync ( ) ---------------
38052 [2026-10-30 21:38:03.990] [metadata] [info] Metadata delta stream starting…
38052 [2026-10-30 21:38:05.995] [background] [info] Marking all folders as `busy`
38052 [2026-10-30 21:38:05.996] [background] [info] Syncing folder list…
38052 [2026-10-30 21:38:06.138] [background] [critical]
And error
Certificate Error (IMAP) Mailspring could not verify this server’s certificate. If it is self-signed or issued by a private certificate authority, install it in your operating system’s trust store (Keychain Access on macOS, the Windows certificate store, or the system CA directory on Linux) and reconnect - on macOS it must also meet Apple’s current requirements for TLS server certificates. “Allow insecure SSL” does not bypass certificate validation.View Log
