Read Receipts Missing
I had read receipts on my mail account which I deleted as there was issue with the configuration. I added the same mail account again but the old mail account did not have the read receipts time stamps for the mails which was sent previously before deleting the account. Is there any possibility to get those back again?
It depends on whether the re-added account got the same internal ID. Read receipts (and snoozes, reminders, etc.) live on Mailspring’s servers keyed by your Mailspring ID plus an account ID, and that account ID is derived from the email address together with the IMAP/SMTP server and username.
  • If you re-added the account with the same address and same server/login details, the ID is identical and the old receipts are re-downloaded automatically as the messages sync back - give it time to finish the initial sync and they should reappear on the old sent messages.
  • If the login details changed (a different username or a different IMAP/SMTP server), the new account has a new ID and the old receipts are still filed under the old one. There isn’t a way in the app to re-attach them, so unfortunately they won’t come back on those older messages. New messages you send will track normally.
