Reading pane show red error message after opening an email, then will not reset on reading subsequent emails
1.Open error report from our LISTSERV box
Reading pane background turns red and displays:
SyntaxError: Invalid regular expression: /**********Pleasegotohttp://www.coe.uky.edu/lists/kylists.phpf=orsubscribingorunsubscribingfromCKMHS-STA**********
–==REDACTED ==–
RegExp too big
at String.search ()
at Object.unwrappedSignatureDetector [as default] (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/services/unwrapped-signature-detector.ts:46:58)
at QuotedHTMLTransformer._findQuoteElements (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/services/quoted-html-transformer.ts:218:63)
at QuotedHTMLTransformer.hasQuotedHTML (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/services/quoted-html-transformer.ts:28:17)
at ConditionalQuotedTextControl.render (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/internal_packages/message-list/lib/message-item-body.tsx:33:32)
at ah (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:163:192)
at $g (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:162:264)
at eh (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:171:13)
at ai (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:202:255)
at bi (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:203:271)
at Fi (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:218:174)
at Gi (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:217:174)
at ii (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:214:252)
at xg (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:212:94)
at Object.enqueueSetState (/usr/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:133:223)
at MessageList.Component.setState (/usr/share/mailspring/resources/app.asar/node_modules/react/cjs/react.development.js:373:16)
at _MessageStore.MessageList._onChange (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/internal_packages/message-list/lib/message-list.tsx:330:10)
at EventEmitter.eventHandler (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/global/mailspring-store.ts:119:23)
at EventEmitter.emit (events.js:215:7)
at EventEmitter.emit (domain.js:476:20)
I thought I should see the message body in the reading pane.
- OS and Version: Slackware Linux -Current (14.2+)
- Installation Method: used .SlackBuild to repackage mailspring-1.9.1-amd64.deb
- Mailspring Version: 1.9.1-30ef802f
This seems to be an issue with automagic signature detection
