Rule has been disabled - Folder could not be found
Pressing the ‘Process entire inbox’ button to apply rules fails and disables all rules - marking them all red - with the error: "The rule has been disabled. Make sure the actions below are valid and re-enable the rule. (Error: The folder could not be found.)
Ignoring the errors and clicking the ‘Process entire inbox’ button again, (with every rule still disabled and marked red) begins to process all emails, as though there are active rules to apply.
So two bugs:
  • Rules are disabled by ‘no folder found,’ even though they exist and were selected from a drop down list.
  • Inbox processing proceeds, even if there are no active rules to apply.
  1. Add a new "Label"
  2. Create a rule to filter by sender, and move all messages to "folder." (is it a label or a folder? seems like a folder.)
  3. Click the "Process entire inbox" button.
  4. After errors appear. Click the button again to trigger a zero-effect scan of the inbox.
No valid rule should be marked as invalid. The inbox should be processed to apply those rules. And if all rules are invalid, clicking the process button should not actually scan the inbox.
  • OS and Version: Windows 10.0.19045
    • Installation Method: MailspringSetup.exe
  • Mailspring Version: 1.22.0-b29ea0e6
Brand new installation. Doing a first time setup. Using IMAP. (no oAuth) After import, inbox contains 30,000+ emails.
Hey @roninpawn thanks for reporting this, I’ll get to the bottom of this and see if we can fix it. I think that this could happen if those folders haven’t been synced from IMAP yet, but that doesn’t seem like the issue here. I bet it’s struggling to match your folder names due to an IMAP prefix.
Thanks, will keep you posted.
