Using 1.15.1 on Windows 11, trying to select messages using the keyboard shortcuts (either default x or remapping it) does just nothing.
Is the keyboard selection confirmed working?
What additional info can I provide in order to figure the issue?
Keyboard selection works, but x only toggles a conversation in the Single Panel layout, where there’s a keyboard cursor separate from the open conversation. In the Two Panel layouts the highlighted row is the open conversation, and x on its own doesn’t turn that into a selection — which is what you’re seeing.
In Two Panel, use Shift+Down / Shift+Up instead: the first press converts the highlighted conversation into a selection and each further press extends it, and Ctrl+A selects everything in the list. From there the usual shortcuts (archive, trash, mark read, etc.) act on the whole selection.
