Send email goes to draft and don't send
My send emails go to draft and dont send anymore
Im also getting emails going to drafts and not sending at all , any suggestions ???
If emails are saving to draft instead of sending, check:
  1. SMTP credentials are correct (Preferences > Accounts > [account] > Connection Settings)
  2. The SMTP server and port are reachable (try sending from webmail to confirm)
  3. Update to v1.21.1 — sync engine stability improvements may help
Also try Preferences > General > Reset Cache which sometimes resolves stuck send queues.
