Sound Effects
Need help in finding the audio sound effects file. like to add a 4db boost to actual file.
cant hear the send email effect. looked everywhere no luck
The Mailspring sound files live inside the application bundle. On Linux/Windows, look in the resources/app/static/sounds/ directory inside where Mailspring is installed. There are two default sounds: new_mail.ogg and mail_sent.ogg. You can replace these files with your own (keeping the same filename and OGG format) to customize the sounds. Note that app updates may overwrite your custom files, so you’d need to re-apply after updating. There’s also a custom-sounds package in the app with higher-quality alternative sounds (CUSTOM_UI_Send_v1.ogg, CUSTOM_UI_NewMail_v1.ogg) that’s used when the custom sounds theme is active.
