SSL Certificate Expired
Hello there,
It looks like your SSL certificate for updates.getmailspring.com has expired. Who can fix it?
https://updates.getmailspring.com/download?platform=darwin&arch=arm64
Checking the certificate from my side, it is valid. Can you please schon a screenshot of the certificate and it’s validity period?
This is only for this subdomain - the rest are fine; you might want to try in incognito or another browser?
I really can’t reproduce this. My browsers all show the certificate as valid:
Bildschirmfoto vom 2024-01-16 16-28-43
Can you please provide a view of the certificate itself so that I can see what is the problem?
It is possible that the certificate is cached in your browser/OS. Can you try this?
➜  > curl https://updates.getmailspring.com/download\?platform\=darwin\&arch\=arm64
curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to updates.getmailspring.com:443
It’s now good to go; thanks for the fix.
