Is anyone else getting this error message when sending out, bulk email to people on a mailing list.
I am responsible for sending out a weekly church newsletter to about 50 people, it does about 20% of email recipients, and then throws up the error message above, which is not at all helpful.
It does not say whether it is the email address that are fault or whether it is Mailspring (application) itself that is blame!
Is there a limit on the number of email recipients?
Edit the image with a program like Glimpse. Select the areas with the email addresses and use Filter > Blur > Pixelize. Then go back, edit your post, and replace the old images with the new images.
P.S. You might want to delete the images from your post in the interim.
Thanks, though…still showing the email addresses. I’ve edited your post(s) to blur it myself. I hate for all your contacts to get doxxed. This is the internet.
Do you have any log files that accompany the error? That will be fairly important to solving this.
Go to “Developer” > “Toggle Developer Tools”
Chose the “Console” tab
Press “Clear Console” (Ctrl + L)
Reproduce the Issue
Do a right click inside the console and click “Save as”
Clear any personal information from the debug file that you now have created
Attach the file here.
You should also check your Mailsync log, ideally right after the error occurs.
