Update breaks most my accounts on issue I don't want to fix
After the most recent update (1.26.2) all my e-mail accounts excelt 1 stop working because of some new check on the certificate that I really don’t care about at all. I want my e-mail accounts to just work. How do I revert to a previous version and please undo this tighter security check, or I will switch to another program.
  1. Just install the update
E-mail accounts keep working
Mac OS 15.7.9, Mailspring 1.26.2
I had the same problem yesterday. Just download the 1.26.1 and install it and delete update.exe. This is a temporary solution.
I was able to change some settings to fix the issue, but from my hosting provider view, the old settings should work also.
Where can I download a previous version? When I go to the download page, when I choose Mac OS, I can only download the latest version.
Try GitHub - Foundry376/Mailspring at 1.26.1 · GitHub . I hope it will work :slight_smile: Click on the green Code button then select Download Zip .
