Hello to all of you.
Is there somebody can help me.
Each time I quit Mailspring and reconnect, I have to reconnect all my Gmail account.
Is there a way to avoid that and keep all the Gmail connected ?
Thank you
Thank you
Google gives Mailspring a long-lived refresh token when you sign in, so you should only ever have to authorize once. If you’re asked again on every launch, the token was saved but couldn’t be read back the next time Mailspring started: the sign-in works, the storage doesn’t. Nothing is wrong on Google’s side.
Two things to try, in order:
config.json instead, which fixed most “re-authorize every launch” reports. After updating, go to Preferences > Accounts, select the account, and click Re-authenticate… once.sudo snap connect mailspring:password-manager-service, and the .deb / .rpm packages are the most reliable option.The full checklist, including antivirus / VPN products that intercept the Google sign-in, is at Connecting a Gmail or Google Workspace account — Mailspring Documentation.
