Problem
Email wont sync
Mailspring Version: 1.13.3-9a7e1a78
Platform: win32
Account State: sync_error
Account Provider: imap
IMAP Server: imap.gmail.com
SMTP Server: smtp.gmail.com
6484 [2024-02-21 16:18:06.294] [background] [critical]
*** {“debuginfo”:“”,“key”:“URL using bad/illegal format or missing URL”,“retryable”:false,“what”:“Unknown exception”}
6576 [2024-02-21 16:18:07.844] [main] [info] Identity created at 1679472878 - using ID Schema 1
6576 [2024-02-21 16:18:07.847] [main] [info] ------------- Starting Sync (willem@proflowpavers.com) ---------------
6576 [2024-02-21 16:18:07.919] [metadata] [info] Metadata delta stream starting…
6576 [2024-02-21 16:18:10.894] [background] [info] Fetching XOAuth2 access token (imap) for 67ebc982
6576 [2024-02-21 16:18:11.046] [background] [critical]
5340 [2024-02-21 16:18:12.483] [main] [info] Identity created at 1679472878 - using ID Schema 1
5340 [2024-02-21 16:18:12.484] [main] [info] ------------- Starting Sync (willem@proflowpavers.com) ---------------
5340 [2024-02-21 16:18:12.487] [metadata] [info] Metadata delta stream starting…
5340 [2024-02-21 16:18:15.523] [background] [info] Fetching XOAuth2 access token (imap) for 67ebc982
5340 [2024-02-21 16:18:15.676] [background] [critical]
12612 [2024-02-21 16:18:17.007] [main] [info] Identity created at 1679472878 - using ID Schema 1
12612 [2024-02-21 16:18:17.008] [main] [info] ------------- Starting Sync (willem@proflowpavers.com) ---------------
12612 [2024-02-21 16:18:17.011] [metadata] [info] Metadata delta stream starting…
12612 [2024-02-21 16:18:20.026] [background] [info] Fetching XOAuth2 access token (imap) for 67ebc982
12612 [2024-02-21 16:18:20.176] [background] [critical]
10016 [2024-02-21 16:18:21.675] [main] [info] Identity created at 1679472878 - using ID Schema 1
10016 [2024-02-21 16:18:21.676] [main] [info] ------------- Starting Sync (willem@proflowpavers.com) ---------------
10016 [2024-02-21 16:18:21.679] [metadata] [info] Metadata delta stream starting…
10016 [2024-02-21 16:18:24.682] [background] [info] Fetching XOAuth2 access token (imap) for 67ebc982
10016 [2024-02-21 16:18:24.834] [background] [critical]
Email Provider
- OS and Version:
- Installation Method:
- Mailspring Version:
