Log
Mailspring Version: 1.9.0-87660767
Platform: linux
Account State: invalid
Account Provider: gmail
IMAP Server: imap.gmail.com
SMTP Server: smtp.gmail.com
14976 [2021-04-16 09:12:52.413] [main] [info] ------------- Starting Sync (xxx@gmail.com) ---------------
14976 [2021-04-16 09:12:52.420] [background] [info] Fetching XOAuth2 access token (gmail) for efa2e010
14976 [2021-04-16 09:12:53.500] [background] [info] Marking all folders as busy
14976 [2021-04-16 09:12:53.505] [background] [info] Syncing folder list…
14976 [2021-04-16 09:12:54.559] [metadata] [critical]
*** {“debuginfo”:“https://id.getmailspring.com/deltas/efa2e010/head RETURNED {"statusCode":401,"error":"Unauthorized","message":"Bad username or password","attributes":{"error":"Bad username or password"}}”,“key”:“Invalid Response Code: 401”,“retryable”:false,“what”:“std::exception”}
14976 [2021-04-16 09:12:54.559] [metadata] [critical] *** Stack trace (line numbers are approximate):
*** ??:? ValidateRequestResp(CURLcode, void*, string)
*** ??:? PerformRequest(void*)
*** ??:? PerformJSONRequest(void*)
*** ??:? PerformIdentityRequest(string, string, nlohmann::basic_json const&)
*** ??:? MetadataWorker::fetchDeltaCursor()
*** ??:? MetadataWorker::run()
*** main.cpp:? main::{lambda()#5}::operator()() const
*** main.cpp:? _Bind_simple::operator()()
*** main.cpp:? thread::_Impl::_M_run()
*** thread.o:? execute_native_thread_routine()
14999 [2021-04-16 09:12:54.604] [main] [info] Identity created at 1579876885 - using ID Schema 1
14999 [2021-04-16 09:12:54.605] [main] [info] ------------- Starting Sync (sebastien.hendrick.hermann@gmail.com) ---------------
14999 [2021-04-16 09:12:54.613] [background] [info] Fetching XOAuth2 access token (gmail) for efa2e010
14999 [2021-04-16 09:12:55.408] [background] [info] Marking all folders as busy
14999 [2021-04-16 09:12:55.409] [background] [info] Syncing folder list…
14999 [2021-04-16 09:12:55.787] [metadata] [critical]
14999 [2021-04-16 09:12:55.788] [metadata] [critical] *** Stack trace (line numbers are approximate):
Blockquote
Platform: linux
14976 [2021-04-16 09:12:52.413] [main] [info] ------------- Starting Sync (sebastien.hendrick.hermann@gmail.com) ---------------
14999 [2021-04-16 09:12:54.605] [main] [info] ------------- Starting Sync (xxx@gmail.com) ---------------
