lephuongbg
(Lê Hoàng Phương)
April 14, 2021, 2:47pm
1
Upgrading to Mailspring 1.9 from 1.8, when I click on the close button, Mailspring will quit instead of minimizing to system tray.
Make sure option “Show icon in menu bar / system tray” is on
Upgrade to Mailspring 1.9 from 1.8 then restart Mailspring
Click on close button
Mailspring minimizes to tray.
Mailspring quits.
OS and Version: KDE Neon 20.04
Installation Method: deb
Mailspring Version: 1.9.0-87660767
Surprisingly, turn off “Show icon in menu bar / system tray”, restart Mailspring, then turn it on again fixes the issue.
Phylu
(Janosch Braukmann)
April 14, 2021, 3:50pm
2
Thanks for reporting this. There is a PR open which should resolve this:
Foundry376:master ← Phylu:bugfix/mailspring-close
opened 04:27PM - 13 Apr 21 UTC
As your already figured out, as a workaround, just switch the tray icon off and on.
marc0303
(Marc0303)
April 14, 2021, 12:16pm
3
Closing the window with the tray option enabled closes the app
Update to 1.9.0
Click on the close button
The app will disappear from the tray and the process to sync mail will be terminated
Closing the window should leave the app in the tray and continue synchronizing mail
OS and Version: Windows 10 20H2
Installation Method: Installer
Mail spring Version: 1.9.0
Started happening after 1.9.0
BTW, Discourse won’t let new users create more than 2 links including headers like “Setup” “Additional Context” etc.
I’m seeing the same issue on Pop!_OS 20.04, Mailspring version 1.9.0-87660767.
hanskokx
(Hans Kokx)
April 15, 2021, 2:30am
5
Is it possible to close-to-try in linux? I’m used to closing my windows when I’m done with them, but I’d prefer for it to continue running in the tray.
iveselin
(Iveselin)
April 15, 2021, 11:58am
6
The same issue on Kubuntu 20.04 after upgrading to 1.9.0, probably related to this feature request
bengotow
(Ben Gotow)
April 15, 2021, 9:32pm
7
Hey folks! Thanks for all the replies here - @Phylu your PR to fix this looks great, will get that merged and ship a patch release for this as soon as we can get in the fix for linux chrome-sandbox permissions. I think that we can also investigate how that config.get()call is returning undefined, it seems like it really should return the default true value.
BlueManCZ
(Ivo Šmerek)
April 16, 2021, 9:15am
8
For me on Linux unchecking and checking again option “Show icon in menu bar / system tray” in preferences fixed this.
system
(system)
Closed
June 9, 2021, 8:11pm
10
