Hitting Home Key or End Key takes to hits instead of one?
Decades on computers here.
Why doesn’t the home key move the cursor home on Text line after one hit instead of two?
Same with end Key?
I opened a bug report here: Can't go to start / end of the line with Home / End keys
I believe this is the same issues you’re reporting, correct @daelv?
This was fixed via PR #2644. Please update to v1.21.1 and Home/End should jump to the start/end of line on the first press.
