After syncing a new account (a ProtonMail one, through ProtonBridge IMAP/SMTP), all is well for about 10 minutes or so, and then all emails in the Inbox disappear from it (one at a time in a short span of about 10 seconds).
The missing messages do not appear in the Archive or when performing a research.
However, they are still in the Inbox on the server side.
The emails show up again from time to time when I check the Inbox folder, and as soon as I open up the Inbox folder they stard disappearing again.
I have a Gmail account also synced in and experience no issues with this one.
To ReproduceâŚ
Sync a new account (ProtonMail in my case)
Wait for several minutes
All Inbox emails disappear
I expect to see all my inbox emails in my inbox at all time
Here is (already) an update, I donât know whether I should keep that as a comment on this bug or as another new bug:
when I check my âall mailâ folder I can only see in the list the most 2 recent mails that are actually in the all mail folder on the serverâŚ
Hi dan,
I did read your bug report before filing mine. Itâs a bit similar, but in my case new emails either show up in the inbox, or totally disappear (and do not show up in the archive).
The emails I see in the archive are supposed to be in the archive (but I only see a small fraction of what Iâm supposed to see).
Yeah I wasnât suggesting you hadnât read mine, just wanted to point out the similarity in case it hadnât been noted
Have you tried clearing the cache in protonmail-bridge? I donât want to speak prematurely but Iâve just done that and re-set everything back up and it doesnât seem to be happening now.
Here is an update.
I tried clearing the cache, thanks @danhead for the tip
It didnât fix the issue but allowed me to observe more carefully what happens during the sync.
Basically, clearing the cache of ProtonMail Bridge removes all email data and disconnects my account. So on MailSpringâs side itâs kind of like a sync reset of some sorts I guess. Anyway hereâs what happens:
m
When MailSpring first scans the folders, the Inbox is âcoherentâ (all the messages that should be there are there).
During âscanning/browsingâ of the other folders (âbalayageâ in French, when the green circle is slowly blinking next to all the folders), itâs fine.
The issue happens at the same time than this scanning is over. All email disappear progressively from the Inbox in a few seconds after the end of the scanning.
Hope this helps
Another element of interest: whenever I start the app, the Inbox is coherent. The inbox empties itself after a time (a few minutes usually). I havenât seen any event that seems to trigger the emptying.
Same issues here, does anyone have any new info on this? I watch all my emails disappear and then thereâs a message that says âHooray! Youâre done.â
I donât know when exactly thisâll be something that Ben can look at. There are a lot of things to do! However, because Mailsync is now open source, anyone else tech-savvy is encouraged to take a look. (Yes, I know the Mailsync build system doesnât work outside of Ubuntu 16.04 right nowâŚthatâs what Iâm working on.)
If there is anything I can do to progress this issue to its resolution, let me know. I can follow troubleshooting steps, send log files, etc. For me, it does appear the emails are being archived in Mailspring, but are still in the inbox in ProtonMail itself. They disappear (Hooray! Youâre done), then re-appear, disappear, etc.
I would also appreciate if this issue could be fixed. Itâs honestly the only thing preventing me from purchasing the pro version of the software and using it as my main email client.
Itâs really frustrating, because Mailspring, while re-syncing all the mails, uses A LOT of web traffic.
My Mailbox is about 2GB, and the Mailspring/ProtonBridge has over 35GB of Download Traffic in the last few daysâŚ
