How can I search through my email by things like message contents, phrases, labels, or folders?
Mailspring builds a search index on your computer, so you can search through your email in seconds. In addition to searching for an email by a name, email address, or subject line, you can search in more advanced ways.
Search message contents
When you view an email message, Mailspring caches it’s content so you can search for it later. Your search queries can include words, phrases, and URLs used in the body of an email.
Search for multiple phrases
Mailspring supports the AND and OR search operators, so you can search for emails based on multiple criteria, for example:
“from:careless@foundry376.com OR from:bengotow@gmail.com”
Search in a specific label or folder
To search a specific folder or label, use the “in:” keyword in the search bar. For example, to search your sent messages for “contract”, you’d say:
“contract in:sent”
Search using Gmail-style search phrases
Mailspring supports other Gmail-style search queries, like “is: unread”, “has: attachment”, and “from: ben@foundry376.com”.
I have a GMail account on my Mailspring.
I notice that when I run a “search” inside Mailspring, I cannot find the results that I’m looking for. From what I understand in the above response, it only caches mail for searching once you read through the email… however I don’t find that to be the case, even if I use Gmail-style queries.
How can I cache all emails so that it is searchable?
The search query as per instructions does not return all the results.
Attaching screenshots to illustrate the issue.
There is a mail from Simona on August 7
Yet when I look for all the mails between August 6th and 7th, it is not there. I tested extended date range too.
My guess is that subsequent replying email, which put this one in a thread, somehow hides the date from search.
Using fairly updated Manjaro / KDE.
