How can I set the language for spell check?
Mailspring automatically detects the language you’re writing in and spellchecks in that language. On Linux and older versions of Windows where dictionaries are not always available, Mailspring downloads Hunspell dictionaries on-the-fly and it may take a few minutes for spellcheck to start working. If Mailspring doesn’t detect the language that you’re typing in, please write a draft in the language of your choice and allow Mailspring to try to download the language in the background.
On Windows 10, macOS, and Linux, Mailspring will default to your operating system language for spell checking your drafts. To change your spellchecking language, you’ll need to change your system language.
On older versions of Windows, Mailspring will spell check in English when your system language is English. System dictionaries are not available for other languages, and Mailspring will not perform spell check if your system language is not English.
See also: Using spellcheck
I’ve just started using Mailspring, and so far, I love it!
But my spell check doesn’t show at all ![]()
I’ve restarted, but no red lines under skjdfkdjs etc.
My settings are set to English UK
Hello again,
Just want to report the Spell Check is still not happening. It’s been a few days now, and multiple restarts.
I really prefer Mailspring over Outlook, but this is a fairly key feature.
Any suggestions??
I can get spell check to work on the Win 10 version of Mailspring ONLY IN PLAIN TEXT MODE
I confirm this. Same error ((
Is there any update on this? Looks like the spell check still only works in plain text mode, which obviously isn’t ideal.
Hi,
Is there plan to automatically detect the language while taping on Linux? I write messages in both French an English, and I constantly have to switch the spelling language in the settings.
