After latest update, mailspring is not able to run anymore.
- Double click on mailspring binary
The program starts…
N/A
- OS and Version: Debian GNU/Linux bookworm/sid x86_64 (Kernel: 5.18.0-3-amd64)
- Installation Method: .deb
- LANG=es_ES.UTF-8
- Mailspring Version: mailspring-1.10.4-amd64
nolddor@computer:~$ mailspring App load time: 191ms [2810:0810/082221.571054:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process. SyntaxError: /usr/share/mailspring/resources/app.asar/lang/es.json: Unexpected token in JSON at position 11870 at parse (<anonymous>) at Object.Module._extensions..json (node:internal/modules/cjs/loader:1183:22) at Module.load (node:internal/modules/cjs/loader:988:32) at Module._load (node:internal/modules/cjs/loader:829:12) at Function.c._load (node:electron/js2c/asar_bundle:5:13343) at Module.require (node:internal/modules/cjs/loader:1012:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.initializeLocalization (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/intl.ts:205:21) at Application.start (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/browser/application.ts:56:5) at App.<anonymous> (/usr/share/mailspring/resources/app.asar/src/browser/main.js:370:24) at App.emit (node:events:390:28) at App.emit (node:domain:475:12) Promise { <rejected> SyntaxError: /usr/share/mailspring/resources/app.asar/lang/es.json: Unexpected token in JSON at position 11870 at parse (<anonymous>) at Object.Module._extensions..json (node:internal/modules/cjs/loader:1183:22) at Module.load (node:internal/modules/cjs/loader:988:32) at Module._load (node:internal/modules/cjs/loader:829:12) at Function.c._load (node:electron/js2c/asar_bundle:5:13343) at Module.require (node:internal/modules/cjs/loader:1012:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.initializeLocalization (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/intl.ts:205:21) at Application.start (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/browser/application.ts:56:5) at App.<anonymous> (/usr/share/mailspring/resources/app.asar/src/browser/main.js:370:24) at App.emit (node:events:390:28) at App.emit (node:domain:475:12) } (node:2773) UnhandledPromiseRejectionWarning: SyntaxError: /usr/share/mailspring/resources/app.asar/lang/es.json: Unexpected token in JSON at position 11870 at parse (<anonymous>) at Object.Module._extensions..json (node:internal/modules/cjs/loader:1183:22) at Module.load (node:internal/modules/cjs/loader:988:32) at Module._load (node:internal/modules/cjs/loader:829:12) at Function.c._load (node:electron/js2c/asar_bundle:5:13343) at Module.require (node:internal/modules/cjs/loader:1012:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.initializeLocalization (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/intl.ts:205:21) at Application.start (file:///tmp/nylas-build/electron-packager/linux-x64/mailspring-linux-x64/resources/app/src/browser/application.ts:56:5) at App.<anonymous> (/usr/share/mailspring/resources/app.asar/src/browser/main.js:370:24) at App.emit (node:events:390:28) at App.emit (node:domain:475:12) (Use mailspring --trace-warnings …to show where the warning was created) (node:2773) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag–unhandled-rejections=strict(see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1) (node:2773) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated Raven: 429 - undefined
